Posted 3/10/2008 19:38 (#330879 - in reply to #330275) Subject: Re: Magnum 7250 hyd detents
Yes you are right I saw the adjustment you are talking about. The # 1 adjustment is already screwed in much farther then the other 3 are. I always thought that adjusted the pressure at which the lever returned to neutral. Is that the same thing?
