Search Forums | Classifieds (35) | Skins | Language
ez antenna info
AgMan
Posted 3/5/2008 17:33 (#326639 - in reply to #326621)
Subject: Re: ez antenna info
Earth
Actually, the issue is not with the Ag15. The Ag15 will work fine with both the EZ-Guide 250 & EZ-Guide 500 as it can handle a fairly wide voltage range. The issue is with the patch antenna (Ag10) that ships as standard with the EZ-Guide 250 - it will work fine on the 5v that the 250 supplies but will not handle the 10v from the 500. Because the 250 has to be able to use the same Ag15 antenna as the 500, the connectors are the same.
