Posted 10/9/2007 11:38 (#216754 - in reply to #216554) Subject: Re: 9760 cracked corn and cobs in grain tank
SW Ontario
Your rotor speed should go alot lower, mine goes to 220. Are you sure you are in low range??
We also run the swept back paddles on our feed accelerator, and it runs at 320rpm which is the low speed.
