sw corner ia. | been doing it for years. I almost (but not quite) enjoy sweeping a bin of corn out in july that is about 20D f and keeps you cool in the bin. Just have to keep the outside moisture from getting sucked in the bottom, goes right up the middle. I hauled several thousand bu. of 16.5% corn this summer all with no damage at all. Most was under 15 but there you go..
I never see anything spoil on the wall if there is no H2O leakage from outside.
Caveat.. you must pull the core out after harvest, level it off again, then freeze the crap out of it to get it to last. | |
