SE SD | I have been using an old kelly ryan feed wagon and it seems to work ok. Am looking at buying a mixer wagon.
We feed ground hay, wet dg's and ground corn stalks. I have been dumping it in alernaterly with the loader, doesn't mix real well just comeing up the ladder feed but works kind of ok for this low budget operation.
We feed 60 dry stock cows, (20 thousand dollar wagon is not in the check book).
What would you all advise for for a fairly trouble free used mix wagon. What do you think I would be spending out of the kid's inheritance.
Thanks | |
