I don't know how much power it takes but I can assure you it takes power and that its a parasitic loss I can live without. Assuming your tractor has a hyd pump why not use that one? As for the hoses, it only takes about 2 seconds/hyd hose to hook them up and I've got hyd lift and swing so I've got hoses anyway. For us hooking/unhooking isn't much of an issue because the grinder hardly ever gets unhooked, basically the only time that tractor gets unhooked is if it needs to be worked on.
Edited by Kooiker 1/22/2011 08:14
