Posted 1/11/2011 09:34 (#1541179 - in reply to #1539978) Subject: Re: Mixing with the TMR
Capac, Michigan
When dumping into a vertical if the load isn't going to be able to cover the top of the screw then make sure it gets dumped right at the edge or it will sit on top of screw.
