Posted 8/26/2010 07:26 (#1332950 - in reply to #1332684) Subject: Re: fairly quick removable post needed to hold corral panels.
North Mo.
My older cousin has done about the same thing except he uses steel pipe then puts another smaller pipe inside that has a disk blade welded to it, works like a umbrella, so it can be remove in the frozen winter, not your problem but is in Mo. Ben
