Posted 8/8/2010 23:25 (#1307044 - in reply to #1305956) Subject: Re: Electric Fence short
sc ia
I've got an electric fence tester but I never bother to use it. My fence has insulated gate handles every so often and I just disconnect them and see if it arcs. If you have a big arc you know the short is down stream and no arc is up stream. A little arc is normal if you have a lot of wire down stream.
