Centre county Pennsylvania, USA | Kyle, great to have you aboard, your expertise is greatly appreciated here.
I just remembered an earlier experience we had with dealer installed yield monitor in a 9500. Dealer had to upgrade the combine speed sensor, Dealer's tech said the speed sensor that came with 9500 was not compatible with yield monitor. That fixed 9500 yield monitor problem. Dealer also installed yield monitor/mapper in 9510, that installed without needing combine speed sensor upgrade. I doubt that's the problem, but it's something else to check. |
