SW MN | That is the pin that links the feedback piston to the front cylinder, takes patience and a long narrow screw driver. If you spin the front toothed cylinder you will see where one end of that goes, the spring end goes into the feedback cylinder with your totally out you might need to remove a side frame and remove one toothed cylinder look up from below and see if you can see the hole in the feedback cylinder.
Edited by SJ72 4/20/2024 15:40
(SnipImage (002) (full).JPG)
Attachments ---------------- SnipImage (002) (full).JPG (65KB - 15 downloads)
