Search Forums | Classifieds (82) | Skins | Language
Deere mobile RTK questions
cyclones30
Posted 2/16/2024 09:31 (#10625716 - in reply to #10625508)
Subject: RE: Deere mobile RTK questions
Midwest
JHEnt - 2/16/2024 07:32 The manuals show requiring entering a mRTK activation which then shows an end date. When you say the subscription, do you mean the stellar support site generates a subscription code that you enter into the receiver then? If so then I think we are talking about the same thing but I didn't realize that should also give you access to the Deere base network run by Lieca.
Yes the end date is the 1 year from the day it's entered, 12 month mRTK.
Yes, you'd call a dealer (that knows what they're doing) and say I've got receiver serial XYZ and would like 1 yr mRTK. 30 seconds later you should have a code and as long as receiver is connected to modem you're set. That code also gives a username and password to be entered on the receiver pages. Instructions are on the mRTK page that shows the coverage map. Username and PW are just versions or portions of the serial and act code from stellar. The instructions also give the mount point, port, and other settings to have correct for where you are.
