| I know. I copied your design. We have one large tire that’s watering a group of cows that’s working fairly well. It’s on a hill & is getting lots of water movement. Also has its own dedicated pressure system. The two causing problems I think have two problems. High ground water has flooded the heat sink pipe. Second is that we located them on existing water lines so when all the cattle start to drink they don’t have enough flow to refill quick enough. This creates an air gap which is a huge problem without a heat source. | |
