I agree w/ Lance but you can "translate" guidance lines to/from JD now. But to do a good job and make it easy, you'd want at least SF3 with implement guidance. Then follow w/ the same SF3. (Or RTK or whatever) Unless you're super flat and consistent soils you could get away with some things
