Search Forums | Classifieds (190) | Skins | Language
Ag Leader liquid control modules - pulse settings
PacerVol
Posted 8/9/2022 14:28 (#9788596)
Subject: Ag Leader liquid control modules - pulse settings
West Tennessee
I run an Integra with Direct Command for two planters with clutches and seed monitors and a pull-type sprayer with a liquid control module/Tee Jet flow meter for rate and section control. The module is mounted on the sprayer with an implement cable running to the tractor. I recently purchased a Blue Jett liquid N applicator that came with a Raven flow meter, Ag Leader liquid control module, InCommand 800 and a 7500 receiver. I powered up the InCommand to get the set up information (pulses, etc.) and then set up a configuration in my Integra. When I swap from the Sprayer to the Applicator, I get a message noting a different Liquid Control module and I accept. It has the correct module for each configuration and the settings (number of sections, width, dimensions, etc.) but will keep the last setting for pulses and I have to remember to manually change this each time I switch implements. Thought this was strange, since it recognized the different module and the settings of the implement. Am I missing something?
