Near Intersection of I-35 & I-90 Southern Mn. | Again I have no experience with your controller. With the Raven the Ag Leader sends the rate to the Rate 1 register. If using a VR map then that Rate could change. I did not use a VR map so my Rate 1 was always the same. Rate 2 or Manual was done on the Raven as before, the results and correct boom indications were done at all times.
I'm afraid I can't help you anymore since my experience with a Raven (which was very good) apparently doesn't apply to your situation. Good Luck. Hopefully some one else with your controller and setup will chime in.
I have not used the serial connection from a 440/450 to the Ag Leader Application Rate Module for some time as I use the Ag Leader Liquid Product Control module instead which controls the rate, maps correctly and most importantly has the ability to shut off the boom and/or planter in sections automatically. |
