Search Forums | Classifieds (42) | Skins | Language
Would someone explain a fusable link please...
Gerald J.
Posted 6/11/2009 19:31 (#741637 - in reply to #741570)
Subject: Re: Would someone explain a fusable link please...
Fusible links are cheaper than fuses and fuse holders. And probably less likely to corrode and open the circuit than fuses in fuse holders. Even copper wire has a fuse rating, at least dating back to a 1928 article in General Electric Review, if not earlier. One problem is that a long wire will have a lot more voltage drop and that's often critical at 12 volts, than a good fuse and like Jon says, it has to get a lot hotter to open than a fuse made of low melting point alloys.
According to a chart in my Electrical Engineering Handbook, #26 copper has about the same characteristics as a 15 amp plug fuse. Blows in 0.3 second with 60 amps. By this chart a #25 would blow in that time with 90 amps, comparable to a 20 amp fuse. A 23 gauge would be about like a 32 amp fuse. A foot of #26 will drop 5/8 volt at 15 amps.
I test insulated wires by pulling on them. If they are springy the copper isn't connected. Insulation is springy, copper isn't.
Gerald J.
