scky | I don't know about the 4wd, I got a 2940 has 5500 hrs. and only one clutch. The only bad I have found wrong with the tr. is a dry clutch. If you are putting a loader on it you will need to be very aware of slipping the clutch because you will have to replace it often. I roll hay with mine and when I back away from the windrow I always use lower gears as not to slip the clutch any more than possible. German tr. made in Mannheim mine has been trouble free.
Good luck | |
