| Thanks for all the info everybody! Turns out when the dealer upgraded me from a 22 to 36 gallon pto pump, they didn't install a relief valve in the bulk fill block. When I turned it on the first time it spiked the pressure and wrecked the bulk fan motor and the 36 gallon pump. We put a new pump on and couldn't get over 2500 rpm's on the bulk fan. Found some rubber material when we pulled the valves out of the bulk fill block. When we get it all cleaned up it should work good! | |
