Nwmo | Thanks for the ideas, after running it a little more today I think the slop must be between the steering wheel and steering valve. While sitting still and turning the steering wheel it takes a little bit of turning before you can hear the valve hissing and letting fluid flow. We just replaced the inner legs that the motor and hub bolt to. The tanks haven't been filling evenly. I think I might wire in some toggle switches to open the rinse valves like was mentioned, that's an excellent idea. Do the little rinse ends inside the tank let enough water through or did you take those off? What exactly happened to Lance? Kevin has been working on this one and he is a heck of a mechanic. They have been emptying fairly close to the same time, I would say within 5 gallon or so.
Thanks again guys,
Devin
Edited by DevinF 4/26/2009 19:26
