Posted 4/25/2009 10:20 (#692360 - in reply to #692317) Subject: Re: Building and air brake system. ?
Eastern Washington
You need a donner truck to donate the parts you need, surley someone close has an old truck that needs to be scraped. To bad about the wedge brakes, there ok if they are still good but if they need work watch out. For a few hundred or less you should be able to find an old cabover that has the motor gone or something and have everything you need plus.
