Central IL | Checking stray wires in cab of the new to me 4630 last night. Found the switched hot and ground the previous owner had going to the planter monitor. Curious part is the switched hot wire would tickle the voltage meter with the ignition off. Digital meter, can't remember now if it was .03 or .3 volts.
Bad iginition switch? Solenoid?
Haven't taken the cowl off yet to discover exactly where the wires are connected. | |
