Classifieds (97)
Case 90 series hydraulic lines under cab?
Machinery Talk
dwag
4/19/2009 22:23 (#686285 - in reply to #685971)
RE: Case 90 series hydraulic lines under cab?
Kirkwood Il.
If the hose portion of the line is bad, I have cut steel part with small tube cutter and replaced hose with another with compression fitting.
casemanwcoh
: 4/19/2009 19:16
Re: Case 90 series hydralic lines under cab?
casetech
: 4/19/2009 19:32
missouri9170
: 4/19/2009 19:39
Re: Case 90 series hydraulic lines under cab?
Essman
: 4/19/2009 20:39
dwag
: 4/19/2009 22:23
Jim in Sask
: 4/20/2009 00:38
dtracy
: 4/20/2009 08:20
