Leeds, North Dakota | beat the heck of bolts, use big punch or air hammer on head of bolt, don't use a impact wrench, use a long 1/2 ratchet and see if they will loosin, work back and forth, no fun, patience, if all goes south, use air wrench and break off, PATIENCE, keep working on those dogs, pain, break off hopefully you have part of bolt that you can weld nut onto and screw out, if not drill out and put helicals inserts in good luck, been there done that, scott. | |
