Posted 4/15/2009 00:28 (#680889 - in reply to #680391) Subject: RE: Can a front wheel assist pull this
We pulled a 27ft flexi-coil 5000 air drill with a 1330 tow behind tank with a JD 8100(160hp i believe with a 20% chip) Thats in fairly heavy land, with usually good to excess moisture. It pulled it quite easy. Hopefully that helps you decide.
