Posted 3/23/2009 17:22 (#653926 - in reply to #653862) Subject: Re: Dry fertilizer on IH 800 12/30 planter
I have a 900 12/30 trailing,dry fertilizer, early riser monitor, field ready shed kept on your truck for 4200.00.
As for using the insecticide for fertilizer, you probably wont be able to get the rate you need. The weight of the fertilizer will probably jam the seed drives.
