Posted 3/23/2009 12:58 (#653677 - in reply to #653667) Subject: Re: John blue pump from Sunday PIC
Owings Maryland Calvert county
You are missing the hand wheel used to set stroke it has a plate with numbers and pointer that has a bolt to hold it where you set it also you need the slide chart for your model from John Blue to set it by.
