North Central Kansas | I bought a 24" bit for my digger. When you plant a post that size it is solid. I just use a single brace instead of a double. Plant a similar size post for the brace and you have a corner that will last forever. Definitly won't be pulling out of the ground. I also put mine in 5' deep. I guess I think if you are going to that much work you might as well do it to last. | |
