Posted 3/8/2009 18:09 (#636250 - in reply to #636242) Subject: RE read your posts........
Ohio
The single extra sprockets on the end of planter is for the seed spacing transmission under neath the seed box.
The fert sprockets are on the fert drive shafts and are 3 sprockets welded together and slide on the shaft until they line up with each other to get the tooth numbers you need for your rate.
