| I have had two B & W's in my last two trucks. I have not had one get stuck other than when it was frozen in. It rained then turned off very very cold and froze stuck. I do keep my lubed up though so I can get it out, that might be key, but it also makes it a little messy to pull and flip. You are much farther south so freezing shouldn't be much of an issue for you but I could see the sand locking it up if not lubed up. Just my two cents | |
