nc IA | When the brakes are on the towing vehicle, the towed one is showing steady lights on the turn signals - I did some more checking tonight, and that is the way the factory dodge 7 RV is set up, brake lights are the same as turn signal lights, Issue I gave myself is trying to hook into a vehicle that uses seperate bulbs for brake and turn - which is a problem only because the turn lenses are orange instead of red.
Looks like I'll just be stopping at fleetfarm for a set of magnetic ones - which wouldn't be half bad to have pulling equipment around either from time to time. Probably better then the stand alone magnetic LED's I got now.
Thanks everyone for the help. Appreciated. | |
