Near Intersection of I-35 & I-90 Southern Mn. | I have purchased a used 8 channel ISO module from a fellow AgTalker and have ordered what I hope are the proper support products from Ag Leader, This is for 6 sensor monitoring only at this time.
This includes the IBBC cable leading to the tractor, the CAN repeater kit (not sure if I needed that or not). Six weigh bar kits, 6 tee cables to lead from the row modules to the planter frame, an ISO implement switch module and wiring tee. A female and male local terminator were also ordered. I will obtain or make the extensions to go between the various row tees on the frame to tie it altogether. The IBBC connector on the tractor currently just ties into the Deere CAN. A breakout/hijack cable will likely be needed to "pipe" the ISO over to my InCommand 1200 inside the tractor.
Anyone notice anything I'm missing? Thanks to all for the help.
Edited by tedbear 3/27/2018 13:08
