Alberta, Canada | I had not tried loading a saved field. The only times I wanted to change implement set-up was because I had originally started out with a 26' heavy disc behind the 4wd. Did the headland + roughly 20 acres, then put a 28' heavy disk behind it, and put the 26' on the FWA.
In this case, adding another A-B line worked fine. However, in another case I'd wanted to adjust some settings (particularily the front/back offset of it) in order to improve performance on the curves/corners.
Since it was performing so well, with max 2" off-line, averaging 0.5" offline, I wanted to reset my overlap so as not to have 400" of nudge by the time I got to the other end of the field. I basically wanted easier adjustment for on-the-go, without having to start over. Something simple like the ease of adjusting steering agressiveness on the go.
I'd also like a mapping feauture, particularily something flaggable (ie for rocks, foreign objects, etc).
Edited by JoshA 10/23/2008 14:31
