Central To Everything and Close to Nothing | <p>You won't need the APER wire but you can use the pressure sensor if your system has one but again not required for the GS2 RC. I believe the APER wire allows for the control valve to tell the DJ controller what position it is in but I could be off on that one. I have a few of these running, and it works really good. </p><p> Just wish JD would get off their duff and support this platform.</p><p> As for cabling, you can purchase a PF90576 or PF 90575 harness from JD and cut the Raven ends off and put on three (for flowmeter) and 6 (for control valve) pin weatherpack connectors. You will also need to change the power for the flow meter from the 5volt to a 12 volt pin, which I have used #37 as it is a spare valve power pin.</p><p> </p>
Edited by CB In The Cab 10/25/2009 21:10
