Posted 10/13/2008 22:46 (#481750 - in reply to #481415) Subject: Re: EZ Guide 500 and Ez Steer problem
Bonanza, Or
I think I may have the problem solved. I had changed 2 settings a few days back when I was running a straight A B line near some trees and I kept loosing signal. I had changed the min no of satellites from 5 to 4 and the SNR from 35 to 40. I put them back to 5 and 35 , deleted the field and started all over.
For now it is working right.
Could these two cal numbers cause this problem?
