| They sell a kit to match cutter bar angle to tire size..........from 2" t 4" wedge that attaches to bottom of feeder house hole on header.
Combine gets set on cement pad, with header lifted so flat front plate of feeder house is perfectly vertical.......a measurement back to the ground, and then pik the right wedge.
JD are steel, Lankota are a hard rubber. they also come with new bottom locking pin loops
