NorthCentral Illinois | Installing GS2 on NH3 bar to take the place of my Raven monitor. Got everything hooked up and tried to run an energize system test from the GS2 and the Fast valve has no power. Called salesman and talked to shop foreman told me to check the pins in the 37 pin connector to see which ones are hot.. Two are hot that should be and two that should be hot are not 36 and 37. Called them and had parts man drop off new harness to see what would happen same result two dead pins. They will be here on Monday to try and figure it out. Anybody else have similar problem. The harness that is on my sprayer I had to swap two pins around to make my fencerow nozzles work maybe same problem with NH3 harness. Thanks.
Edited by stripper 9/19/2008 21:48
