roaming | how much "lag" are you seeing with the Pro600?
Regarding guidance not engaging: has the AccuGuide system been enabled? You must enable the system before you can engage. Press the front side of the autoguidance enable switch on the RH console for about 3 seconds. The system should beep and you should get a liability screen on your Pro600. Once you accept the liability statement, the system is enabled, and you should then be able to engage, assuming all other conditions are met (good GPS, swath selected, operator in seat, not in road mode, etc.) | |
