Unless your yield mapping system is really ancient and has never been updated (basically, is the old CYM system), you will be working with Flags5_0.gss. The 3 vs. 5 is the major firmware version. *3_0.gss files can be edited with notepad if VERY careful, but that would likely be a waste as probably no current software would read them. *5_0.gss files containing binary offsets and potentially checksums. It would likely be impossible to successfully edit them with conventional tools. |
