Kingston, Iowa | I'm trying to get my EZ steer tuned in on our 9220. I ran the calibration wizard and have the following for settings:
Wheel base 73 (Front Axle to hinge)
Antenna Height 141
Ant - Axle Offset 2 Forward ( I built a bracket)
Angle 8 Degrees
Freeplay left 0.0
Freeplay right 0.0
Motor Speed Auto
Online Aggress. 102
Approach Aggress. 110
All of the above settings had the least error online in the calibration wizard.
My main concern is when I make the turn on the end, if I don't have the rear of the tractor heading in the right direction, it will take off until it gets far enough offline to disengage. Will changing the approach aggressiveness help this?
Any thoughts, Ideas or recommendations for different settings would be appreciated.
Thanks
Jason
Edited by Jason Hinson 8/24/2008 09:28
