Canby, MN | If you click on the "Harvest" operation just above the individual loads it should show a summary of all the loads on the right side of the screen. If you want to print that out, just do a right click on the summary screen and choose print preview or print to see what it will look like. If there is too much info to make it on one page, then choose "Edit General Summary Design". Then use the red X on the right side where is lists the selected items to remove columns that you don't want. | |
