North west MN | Yes there is a limit on AB lines what I have done in the past with the EZ-Guide EZ-Steer is set the swath to a foot then when I run out of passes I just reset and do an A Plus. That will keep the same heading and give you another 1028 lines. I never took the time to get everything centered with the EZ-Guide although it could be done with and implement offset and then set to correct width. | |
