Little Eqypt - Southern Illinois | You have a Garmin 16HVS. Use them all the time for Yield Monitor and for Soil Sampling. Work great. Have three or four on the farm now. Reprogramming is pretty easy. However whom ever set that one up did not do you a favor, IMO, that setup is pretty sad and shaky with the adapter. Do yourself a favor and cut off the plug and wire it up for 9 pin. It will last a whole lot longer. The first one of those we got came that way, and now we cut them off and pin them up with a real connector.
you will need an programing cable with a power sour se to do the reprogramming.
Good luck. |
