South central, Nebraska | If you use the HEADLAND mode to make your boundary you have to stay with either the A+ or A-B line you created with THAT boundary pass. If you switch to another line then the booms will turn on outside the boundary you defined in your headland pass.
It ONLY works with straight A+ and A-B lines defined with the HEADLAND mode. It will NOT work with any added lines or ANY curved lines.
I had ask Ag Leader why curved lines and freeform lines are not available for the HEADLAND definition and was told you could buy an INSIGHT system to do that.
