Readlyn | We lost a compressor. Low voltage. Got a beefier one from AutoZone, installed closer to the tractor and ran double 10 gage wire to battery with a Deere relay ( RE44651 ) Very heavy duty, rated for continuous ON. We run 2 air tanks at the rear of the planter, one for each half of the 24 row planter. No clutch problems in 5000 acres. Lost a couple of shear pins. Will be on all planters from now on. | |
