Search Forums | Classifieds (137) | Skins | Language
2144 unloading auger
Jon Hagen
Posted 7/3/2008 22:53 (#409392 - in reply to #409366)
Subject: Re: 2144 unloading auger
Hagen Brothers farms,Goodrich ND
Also on the greasing, If you don't want to grease it moving, atleast grease it at 1/2 way out, fully out and parked on the rest.
Do the 21's still have that support rod on top of the horizontal auger like the 14's ? If so, the rod wears where it pivots on the grain tank and eventually sags enough to bind up the turret. When this rod is correctly adjusted, a few pounds of down pressure on the end of the auger will allow the turret swivel to rock from touching the front to the rear of the turret base. In effect, the auger should "float" without putting any bind in the swivel joint.
