Leesburg, Ohio | Started spraying today with 8420/GS2/RateController/Bestway pull-type sprayer for first time. Got along good for about 35 acres.
Hit a washout enough to jar things a bit, and sprayer kicked off. Looped around to cover missed spot where it kicked off, and stopped on end to change min flow rate. After that, will not spray at all. Wants to keep taking me back to calibration test. If I do cal test, will start to spray until I get up to speed, then kicks off with low or high rate message, takes me back to same cal test screen. Sprayer will perform all stationary tests with no problem. All connections have been unplugged and plugged in, did cold reboot, recycled power several times.
Couple hours with Stellar, couple hours with dealer, now dealer is fileing D-Tach.
Any similar experiences? or suggestions?
Thanks! | |
