Posted 6/16/2008 10:36 (#398793 - in reply to #395164) Subject: Re: Omnistar XP Convergence Ez-Guide 500
A trick to getting convergence quicker, is to not use the autoseed feature when moving equipment. If you turn off the autoseed and unplug the lightbar before you switch fields (especially if travelling under power lines) you will usually get convergence back quicker.
