Sutherland, IA | While we're on the subject...I was in the middle of planting a corn field the other day and went from a split planter configuration to a single variety configuration. I told it to add to last map when it asked but it went ahead and created a brand new map. Normally this would not be a big deal but this was a very cut up field and I was skipping over some area's and giving them a couple more hours of drying and then coming back to them. My first thought was to load a refrence map but like Scott said it won't let you.
Also to add to this dad said he has the same problems when spraying which sound even more annoying. He'll spray part of a field and then change products when he fills up by adding something like glyphosate to the mix. Then he has no refrence of where he has already sprayed in the field. Hopefully the agleader guys are listening and can solve this problem for us. Let us know scott if they tell you a way around this problem.
Edited by dmaxdiesel 5/29/2008 10:50
