| To install in an appllication with the 4400 you need one of two cables. The first cable will adapt the 4400 harness to the two connectors that are on the back of the EZBoom. Then the EZBoom will replace the 4400 and do rate and boom control. The second cable available is the "T" cable that will allow the Raven to control rate while the EZBoom controls the boom sections. In either case ease of installation is dependent upon whether the wiring harness was altered by Apache. Since you are using a 4400 (I think it has the section control switches on the controller) this should be fairly simple with the correct cables. If you want more specific help, feel free to email me.
Here are the part numbers (first number CNH, second number Trimble)
EZ-Boom to Raven 4XX0 âTâ Cable 87298831 59942
Raven 4X0 to 4X00 Harness Adapter 87298832 59943
Joe
